When I use a snippet it shows the snippet twice. help
Hi @user591,
Welcome to the forum
If are using both the Text Blaze extension and the Windows/macOS app, which is causing the snippet to trigger both simultaneously. To avoid this, you can disable the desktop app in Chrome-based browsers by going to the "Options" menu in settings and changing the "Windows/macOS app in Chrome-based browsers (like Chrome and Brave)” setting.
