So I love Text Blaze so far!
I was able to import a single textexpander snippet using the options in my account.
I did notice an issue--some of the snippets I imported have optional sections of text, and once imported, while I can see the box where to click/ select the optional text, the text itself only shows up when I click the box--there there a way to edit my snippet so I can always see the text whether I select the optional checkbox or not? It would just help me read the entire snippet a bit easier!
My next project is setting up a new textblaze snippe to make myself a patient note using data entered into a data blaze field--so I don't have to retype any field, just enter in form, active snippet and create note!
