Some small keyboard tweaks
Hi
Can I make a couple of small suggestions while using the pop up view with a keyboard?
  1. When you have a snippet selected within a folder, pressing Left should collapse the folder you're in and leave the folder selected. This would help navigating from the middle of one folder to the other folders.
or
  1. Pressing Cmd+Up (or Ctrl or Alt or Shift or whatever) should jump the selection up to the current folder. That way you could press left to collapse it and go on to select other folders.
Both of these are essentially the same thing, but 1 is a single keystroke quicker.
Hello,
Thank you for your suggestions, these improvements sound great. We'll consider them to improve the keyboard navigation of the app.
If you have any other feedback please let us know!
