Sort snippets inside folders by usage, name or shortcut
I think that would be really great to have a sort feature inside each folder to organize in easy and fast way all snippets.
Sometimes we have a lot of snippets inside a folder, and having a way to sort them can help when we share a folder or just to have our Text Blaze more organized.
It can be useful also to quickly find conflicting shortcuts, since as now there isn't a way to find all conflicting shortcuts in an easy way.
Regards,
Diego.
Thanks for the suggestion @Diego_Suancha.
On a related note, you can drag and drop snippets to change the order as you please.
Also, when you have conflicting shortcuts, you can mouse over the notification at the bottom left to see which shortcuts are conflicting. Another way is to use the search bar and start writing the problematic shortcut. This will give you a list of all shortcuts containing that string of text, which should help you identify where the conflict is.
That said, we've taken note of your suggestion :slight_smile:
Thank you so much for the advice @Cedric_Debono_Blaze.
I mentioned these features because of this:
In this case this is half of the snippets that I have in this folder, and as you can see, It will be really hard if I wanted to sort this folder in any way :3 I know that maybe this is my fault for creating a lot of snippets, but that is why.
Regarding the conflicting shortcuts, for example I have one that is CC as you can see here
Screenshot 2021-09-16 3.02.32 PM
If I search CC in the search bat it will give me this:
Screenshot 2021-09-16 3.06.32 PM
And here there are like 40 snippets that contains the "CC" string.
And again, than you for the time Cedric :3
I see, thanks for the clarification @Diego_Suancha - you make a valid point. Organizing your snippets definitely shouldn't become harder when you have many snippets. We'll see what we can do.
In the meantime, if you wish we could jump on a call, maybe I could give you some advice on how to build snippets in a way that reduces the number of snippets you have.
Let me know.
For conflicts, you can navigate to the "cc" snippet. Then hover over the orange shortcut with the conflict icon and it will tell you those specific snippets that "cc" is conflicting with and allow you to navigate to them directly.
Note that this feature is new and was added in the past two weeks or so.
Sorting is something that comes up occasionally. I'll file an internal issue for us to keep track of and we can tackle it when there is availability.
Just to add:
It would also be helpful to be able to auto-archive snippets that haven't been used, e.g. in 6 months.
It would be even better than just sorting them based on usage and manually deleting the oldest ones, since the purpose of removing them would be to have a better overview and reuse the snippet shortcuts in a better way.
But the archive would make sure that if the edge case occurs again you still have the backup of the snippet.
With this feature I'd be able to quickly reduce my snippets by probably up to 80% on an ongoing basis.
Hey Michael, welcome to the community!
Thank you for the feature idea! We'll discuss this option internally.
As an aside, this is an old issue and we have added support for sorting folders by "Name" and
"Shortcut" a while back. Note that we don't yet support sorting by usage.
To access sorting, right-click on the folder and then "Sort by"
Thanks! I wan't even aware that there's an extra context menu probably because everywhere else outside of the sidebar the Chrome context menu shows up instead.
