It would be great to have the ability to sort snippets in the dashboard via data modified, date created, alphabetical, reverse alphabetical, etc.
Could you give an example of the use cases for this. E.g. why would I want to sort by last modified.
The default order if you don't move things around is the order they were created. If you created these in a batch import though, their relative creation dates are basically random.
You can drag and drop them to rearrange them and move the two /zoom's next to each other.
Having an option to sort though is a good idea, I'll keep it on the list.
Automatic sort by alphabet would be great!
Hi, is automatic sort by alphabet an option yet please?
Hi @deb Welcome to the forum!
Automatic sort by alphabet by is not available yet. You can vote on this feature request to increase its visibility.
Sorry if I do not understand, but you can sort snippets within a folder by alphabet.
Hi @George_Marinos , the suggestion made by @deb is to enable automatic sorting of snippets. Currently, we have to manually sort the folder each time we add/change snippets inside it.
