Demo of how to split clipboard contents and assign the resulting individual items to variables.
Highlight the three lines below and copy them into your clipboard:
The first line of text
The second line of text
The third line of text
This is what they look like when I use the split() funtion to break them up at every line break:
{=split({clipboard}, "\n")}
What you see above (inside the square brackets) is an ordered list, which you can read more about here.
I can also choose a single item from the list, and then assign it to a variable like this (only visible in the snippet editor window):
{line1=split({clipboard}, "\n")[1]}
{line2=split({clipboard}, "\n")[2]}
{line3=split({clipboard}, "\n")[3]}
The commands above will not give any output, because they're being assigned to variables. To insert them, I need to put my variables inside my snippet like this:
{=line1}
{=line2}
{=line3}
In my split() function, I used "\n" to instruct Text Blaze that I want to split the contents at the line break. This is called a "delimiter". Other delimiters include "\t" (tab stops), alphanumeric characters and many more.
You can learn more about this here.
