I see questions and feature requests regarding this from 2019, and still not yet supported! Why is that? it's legit keys and a very popular ones!
Hi @shimon.amir Welcome to the forum! ![]()
Thanks for raising the request. Would it work for your use case if we enable support for Home/End keys in the Text Blaze desktop app (macOS/Windows) first?
Starting with the extension is a bit tricky because we would need to ensure compatibility with different operating systems.
Hi, it would be very useful, as my primary usage is with apps within the operating system, and very little on the web.
Sure. We will look into supporting it for the desktop app. I'll keep you posted on any updates.
Thanks, waiting anxiously ![]()
I would second @shimon.amir request on the home and end key. It would be very useful.
