Hello everyone
if there a way to suppress output:
I would like not to print this out.
{formtext: name=number; default={clipboard}}
Yes, you can use the {note} command for that.
Here's a very basic example.
{note}
{formparagraph: name=number; default=Some text (you can use the \{clipboard\} command too)}
{endnote}
{="Here's the text you entered: "&number}
{note} also takes a number of settings, including trim, preview and insert.
{note}This section will show up in the popup window when inserting the snippet, but the contents inside the note command won't be inserted. Notice the gray wavy underline.
{endnote: trim=right}
{note: preview=no}
This is some text that will not show up in the popup window when inserting the snippet, and will not be inserted either. This is handy for when you want to leave a note for yourself in the dashboard, but don't need to see it any other time.
{note: preview=no; insert=yes}This text will not show up in the popup window but will be inserted when you insert the snippet. This isn't used often, but might have some applications.{endnote}
hello, {note} doesnt seem to be supported anymore. How can I suppress the input of a formtext in the output?
I just want to use the formtext-input for further calculations.
{note}'s are definitely still supported and aren't going anywhere.
Make sure you have {note}...{endnote} around your contents. If you miss either the start {note} or the {endnote} it won't work.
Thanks. Work's perfect
