Text Blaze posting clipboard rather than Snippet
I have run into a recent issue where Text Blaze will only post whatever data I have in my clipboard (Control+C) rather than my snippet. I will return to my dashboard, confirm the snippet, complete the "try it" selection and still only get the clipboard contents rather than my snippet. Help?
Hello Jeff, welcome to the community!
Is this issue happening with all of your snippets, or just some of them? By any change are you using the {clipboard} command inside such snippets?
If this is happening with all of your snippets, and reloading the extension doesn't fix it (by right clicking anywhere, then Text Blaze, and "Reload extension..."), could you send me an email at obed@blaze.today so we can schedule a call to look into this together?
Hi Obed - It's only happening with a couple snippets. I'll send you an email
Hi Obed is there any update to the interference from CrowdStrike's Falcon Sensor extension? IT team is not willing to disable.
Hi Jeff, just to clarify, this issue happens due to CrowdStrike's Falcon Sensor extension. It injects itself on every page within the browser and modifies the paste action. Since the paste action is also used by Text Blaze to insert your snippets, this prevents our snippets from being inserted correctly.
We have reported the issue to CrowdStrike. As per the latest email, they are working from their end to fix this issue.
In the meanwhile, if disabling CrowdStrike not an option, as a different workaround, you can use the Text Blaze Windows app (Text Blaze: Snippets and Templates for Windows), which is unaffected by CrowdStrike's browser extension. If you do this, you'll need to disable the Text Blaze browser extension first.
Let me know if you have any questions.
Hi, this is similar to an issue I asked about. I have to enter my snippet code 2-3 times before it works, otherwise it keeps pasting the last item I copied. Is it possible this has anything to do with an extension? I know when I work with a different copy, we are told not to add an extension.
Hi @Jill_McLaughlin could you please email us at support@blaze.today? One of us can join a call with you and take a look at this issue. Thanks!
