Is there a way to control where the text plays window pops up? I'm using a 43 inch monitor and when I'm working on the lower right corner the text blaze pop up is always very far away in the upper left corner of the monitor. I doubt it is currently a setting, but it would be great if there were a way to have the window pop open in closer proximity to the field I am currently entering text into. Perhaps it should always attempt to pop as close as possible on the left (or right) of the current in use window depending on the current window position?
Hi @kbross, welcome to the forum. ![]()
Currently, the popup window remembers the last position you moved the window to, so you may move it a position where you feel comfortable with. Unfortunately, there's no way currently to make it close to the field you're triggering from.
If you find that the popup window is not remembering its last position, please let us know and we'll look into it.
