Using as a workaround for em dash without num pad. Have to add a space and then remove every time, super annoying.
Hi @Douglas_Schwartz! Welcome to the forum.
By default, snippets only trigger when the shortcut is typed after a word break.
You can change the configuration for a given folder by clicking on the folder name and then changing the Snippets trigger
configuration on the bottom right-hand side.
Helpful!
