For some reason the updates I am making to my snippits are not working when I use my shortcuts. Anyone know why this is happening today? My formulas are not working right and the changes I made to some shortcuts today are not working but if I use the old shortcut that is no longer in text blaze it will work. Hard to make progress with work when the new updates I need in my snippits are not working.
- Right click with your mouse on the page
- Select the Text Blaze option
- Click on "Reload Extension..."
It looks like an overnight update corrected everything but if this happens again today I will try your suggestion. Thank you so much!
Do these steps do the same thing as removing and reinstalling the extension? I remember in the past we did that for troubleshooting to force an update.
Hey Andrew, these steps are slightly different than re-installing the extension. That said, for this particular issue, either of the steps will resolve it. Restarting the browser will also resolve it.
Thanks for this guidance! For days, I've been wondering why updates I'd made to a snippet were not showing up (and the "Try it out" wasn't showing the updates, either) and a right-click-reload of the extension seems to have fixed it!
