I'm new to Text Blaze and I'm testing it out.
Is there a way to trigger the completion as soon as I'm done typing periods, even if there is no space before?
I use completions like this:
.en. -> –
But I need to expand them as soon as I type thesequence, event if there isn't a space before. Is this possible? They work fine if I type them in fron of a space.
I looked around but haven't seen the answer. I'm not sure if it's because I'm not looking for the right thing.
Thanks,
L
Hello, welcome to the community, I hope you'll find value in using Text Blaze.
You should be able to achieve this by changing your snippet trigger options. You can see them by clicking on your snippet's folder, on the right-hand side.
You will see three options, if you select "Anywhere", your snippet will always trigger as soon as you finish typing the shortcut, without needing to have a space before it.
Let me know if that solves your issue!
Aaahhhh!!! OK, I was looking at a per-trigger option, which is why I couldn't find it.
Yes, I did what you mentioned and I get the results I want. Thanks!
L
