Hi!
I'm finding it difficult to use the value from formatted output (,.2f)
I.e I have the value 47,9655, which is a result from a formula. In formatted output it shows as 47,97.
In the next formula I want to multiply the output value, and not the actual unformatted value.
Any ideas?
Hi @benjamin.tolfsen, sure, you will need to create an intermediary variable. here is the sample snippet.
{val1=47.9655; format=,.2f}
{val2={=val1; format=,.2f}}
{=val1}
{=val2}
Here, replace val1
with the output from the previous formula and use val2
in the next formula.
This can be further optimized, based on how you use the variables.
