I'm trying to use a CSS selector and when I do test it I get this.
"[Error - You must install the Text Blaze extension to use the {site} command.]"
The extension is installed, which is how this was replaced from its shortcut
Not sure how to go forward from this as I'm trying to grab an email from a CSS selector. (a long one, unfortunately)
div#main_panes section.ember-view.main_panes.split_pane.ticket.fr-focus > div.pane.right.section.with_apps_pane > div > div > div.header.pane_header.mast.clearfix.web > div.editable > div > span.ember-view.sender
Anyone also have any extensions they recommend for easy CSS Selector extraction? I'm using one that's done well but not sure this format will work with Text Blaze or if I'll need to manually remove the >
