Hi there
I'm using text blaze in google docs and noticed a couple of issues.
The 'place cursor' function doesn't seem to work and when inserting a snippet that includes a table, the table formatting changes when inserted. Is there any way to resolve these issues?
Hi @Elena_Berta
Can you share a sample snippet with us that contains the table and the cursor command? You can duplicate the snippet and put the snippet into a folder and share it with me at gaurang@blaze.today . Let me know once you do that.
Thanks Gaurang! I've shared the folder with you. The cursor seems to be working now, not sure why it wasn't before.
With the table, when I insert it into a google doc the borders change and the font size in the first row is 11 (which is what I want) but then in the other rows it changes to 12.
