Using Text Blaze in other Mail applications and documents
Does Text Blaze only work in Google mail and applications? I have a Mac and it doesn't seem to work when I put my snippet into Apple Mail.
Hi @Julie_Jackson Welcome to the forum! :slight_smile:
Do you want to use Text Blaze snippets in a desktop app? If so, you need to install our macOS app (Text Blaze: Snippets and Templates for macOS) for Text Blaze to work in those apps.
Thanks so much for the quick reply - your solution worked!
