Hi is there a command allowing me to limit the number of character i can enter?
Hi @emmanuel.abel.cnmtl ,
Are you referring to characters in a Form text?
Can you please elaborate on why you need to limit the characters?
Salut @VinodGubbala
Voici la commande que je veux etablir
Complication : {formmenu: Oui; default=Non; name=Complication}
{if: complication="Oui"}
{formparagraph: rows=3; cols=100}{else}
Aucune complication formulé &/ou observé{endif}
Je veux donner un limite de caractère que l'on peut mettre dans ce paragraphe pour eviter de surcharger inutilement la note et obligler a ecrire l'essentielle
Merci
Thanks for the example.
Does something like this works?
{formparagraph: rows=3; cols=100; name=notes}{if: len(notes) > 20}{error: La note ne peut pas dépasser 20 caractères.; block=yes}{endif}{else}
Suggestion on top of it. If you just wanted Oui/Non,
You can use {formtoggle} which makes it simple to use. Something like
{formtoggle: name=Complication; default=no}
{if: complication}
Excellent!!!!
Cela repond a ma question
merci beaucoup
