I have connected the account using the API key and the connection tests as successful.
I have two rows of data in Data Blaze
I have cleared my Chrome cache for both Zapier and Data Blaze
I took the table id from Data Blaze Dashboard ID**/view/0ijuJLDAccr3p1xfMrd556/
When I try to test the trigger, no rows are found.
Can you check your API token from Data Blaze to make sure you have 'Read' selected in the API token menu?
By not working, do you mean that the rows do not show up when you click 'Test Trigger' in Zapier? If that is the case, can you double check that you have given Zapier access to your Data Blaze account? There should be a pop-up asking you to give access.
Or do you mean that the action step isn't working? If that is the case, please check Zapier and see if there is an isuse with the action step you've set up.
@Jonathan_Burns As you're testing the row created event, this trigger will fetch only the recent rows, can you please try to add a new row first, and then immediately test the trigger again?
