Click on specific button
Hello together,
i wanted to click a specific Button with the id and class to select the Button.
If i use the Selector Tool it says it only has one match. But when i try to run the sample it says the button cannot be found. But it is visible in the front end and i can click it myself.
Why it doesnt work?
Kind Regards
Steallight
Hi @SteallightDesigns,
Could you share selector and page where you attempt to trigger the snippet?
Hi @Mansur_Kutybayev
{click: selector=#reporter-val .aui-button-text}
Are you available to have a call through a Google Meet to look at this issue? Please email us at support@blaze.today and we will schedule meeting.
@Mansur_Kutybayev
The Problem is there is sensible Data on this Site. So i cant probably show you the site itself
Hi @SteallightDesigns Welcome to the forum! :slight_smile:
Please right click on that button (that you wish to click on), then click on the Inspect option in the menu. Then the HTML code for the button will open on the right side. Can you please share with us a screenshot of that HTML code? It will help us understand the issue better. Thanks!
Hi @Gaurang_Tandon
sure i blacked the sensitive Informations
Thanks for sharing this. I tried to reproduce the issue in a similar setup but I am not able to.
Can we have a call to check this? I don't need to see the website itself, but there are some logs that I would like to gather. Please feel free to email me at gaurang@blaze.today
Hello i wrote you an Email
Thanks for joining the call today. As discussed, we cannot yet use the {click} command across iframes. This feature is planned, although we have no updates as of now.
I recommend following this discussion to be notified when updates are posted: How to move into an iframe/textarea
Text Blaze is now able to move into and out of iframes - within a single snippet - with the updated {click} command. Please take a look at this post from May:
If you face any issues with automating actions across iframes, feel free to let us know. Thanks for your patience :slightly_smiling_face:
