Error handling with the Click command
So, I've been loving the recent update that allows us to use CSS selectors to direct the click command. I also really like that it interrupts the snippet if it can't find any matches to click.
However, I do wish that there was a way to have alternative error handling. Something akin to the "catch()" function, but as a command. That way if a command fails (whether it be a query that didn't work, or a click that ran into issues) it has an alternative to use.
The main use case for me would be a delayed re-attempt to click. Most of the time if a click fails it's because it didn't wait long enough for the page to load. One fix is to extend the delay before clicking. However, if 90% of the time the page loads in 0.5 seconds, and 10% of the time it takes between 0.5 and 2 seconds, it would be much more efficient if it tried at the 0.5 second mark, then if that fails a catch has it wait another 1.5 seconds before trying again. The alternative is waiting 2 seconds each and every time.
Does anyone know of a way to use iserror(), catch(), {if} or {error} to do this?
Hello Patrick,
One way of doing what you need is using if conditionals to verify if the element exists using the {site}. Once you know the element exists you can proceed to click on it, or wait for longer. I added text to show what is happening:
waiting 1 second{wait: delay=+1s}{if: catch({site: text; selector=.navigation-controls2; page=https://community.blaze.today/}, "not_found") <> "not_found"}{click: selector=.navigation-controls2}{endif}
waiting 1 more second{wait: delay=+1s}{if: catch({site: text; selector=.navigation-controls2; page=https://community.blaze.today/}, "not_found") <> "not_found"}{click: selector=.navigation-controls2}{endif}
Done
Hi Patrick, in addition to what Obed mentioned, I will mention that we plan to soon release exactly this (delayed re-attempt on click command) - although no ETA on that yet.
Unfortunately, this doesn't actually work for my use case.
The {site} command will look at what is present at the time when the snippet is initiated. Which means if I use a {click} to navigate to a different page, following which I need to click on an element which is not present in the first page, but present in the second, then the {site} command doesn't help. It either will always find it (if there is an element on the first page which matches the same selector) or never find it.
This feature is now available in beta. If you're interested, please email me at gaurang@blaze.today to setup the Beta extension.
The feature is now available in production. Visit January Development Update for more info. The new setting is called maxdelay:
