Hi, I would like to type any word, and whatever the way its written would like to change in the format needed. For Example
phrase "best work"
Beggining of sentence: "Best work" Title: "Best Work" all capital: "BEST WORK" lowercase "best work"
How can I achieve that?
Best regards,
See a discussion on this topic here:
Where in the process of rolling out the solution discussed there. Should be another two weeks or so before it reaches all users.
Hey @martinhgps Came across your question while looking for something else. You probably already know that this solution has been implemented. If not, here's the scoop: Quicktip - Capitalizing text
Thank you! -Brad
