Hi @Dan_Barak1
I have added a note in my snippet, which needs to be copied, but it's always underlined, which is annoying.
Is there any way through which I can remove the wavy underline from the note and visible as plain text.
Thank you so much for the help.
Hey @Shairaz_Khan, you can't remove the underline at the moment, but you can change the font size and color to make the underline less visible.
Hi Shairaz, in addition to what Dan mentioned, you can paste your clipboard using Ctrl+Shift+V (Cmd+Shift+V on macOS) to paste unformatted text, which should hopefully avoid the underline.
Finally, can you tell us your use case a bit? In particular, why do you have to copy parts or your snippet to paste elsewhere? Note that we have Text Blaze apps for both macOS and Windows, as well as advanced autopilot, so you can move data from one place to another automatically
(without manually copying and pasting it)
Hi @Shairaz_Khan! There is a feature request up for voting about this very topic. Note color customization Add your vote if you'd like!
Seriously one of the best enhancements made in a while!!!! #itsthelittlethingsinlife
