Parameters in {click} command function
Hello everyone.
I want to submit the idea of having access to some kind of variable in the {click} command.
Actually, I've tried to encapsulate a click command as a function, with and without a parameter. It doesn't work. Here's my use case :
I have autopilot to click on specific elements in my page (using xpath selectors in this case)
I need to click on many elements to change some text in the current web page.
For many of the elements, the xpath are globally the same and will only change one simple element in it
Replace "main param" in page (ex: "FILE")
{click: xpath=//div[@class="oe_view_manager_view_list"]//td[@data-field="key" and div/text()="FILE"]; trim=yes}{key: tab; trim=yes}{key: cmd-a; trim=yes}{key: backspace; trim=yes}newfilename{wait: delay=+0.1s; trim=yes}
Click "Processus section" in page (ex: "PROCESSUS")
{click: xpath=//tbody[@class="ui-sortable"]//td[@data-field="name" and div/text()="PROCESSUS"]; trim=yes}{wait: delay=+0.1s; trim=yes}
Replace "Sub param" (ex: "FILE") • after a Click "Processus section"
{click: xpath=//div[@class="oe_popup_form"]//td[@data-field="key" and div/text()="FILE"]}{key: tab}{key: cmd-a}{key: backspace}newfile(subparam){wait: delay=+0.1s; trim=yes}
I'd like to be able to make things more clean, readable, re-usable and maintanable by creating functions wrapping my clicks as below :
{clickOnMainKeyParameter=(parameter) ->{click: xpath={click: xpath=//div[@class="oe_view_manager_view_list"]//td[@data-field="key"]/div[text()="{=parameter}"][1]}}; trim=yes}
{note: trim=yes; preview=yes}
code exec : clickOnMainKeyParameter(`FILE`)
{=clickOnMainKeyParameter("FILE")}
{endnote: trim=right}
My automation process would need me to make many clicks on similar elements where only a parameter in the selector would change.
Do you guys think that would be possible in the future ?
Best regards,
Rudy
Hi @Rain that's a nice feature request! At the moment, this is not possible as you noticed. Would a syntax like this work for you:
{getXpath=(parameter) -> "//div[@class=\"oe_view_manager_view_list\"]//td[@data-field=\"key\"]/div[text()=" & parameter & "][1]"}
{click: xpath={=getXpath("FILE")}}
Hello @Gaurang_Tandon,
Thanks for the suggestion. I've tried your solution :
{getXpath=(parameter) -> "//div[@class="oe_view_manager_view_list"]//td[@data-field="key"]/div[text()="" & parameter & ""][1]"}
{note}{=getXpath("dossier")}{endnote}
{click: xpath={=getXpath("dossier")}}
// I had to escape the line in the post form so in case I doesn't render right, here it is :
{getXpath=(parameter) -> "//div[@class=\"oe_view_manager_view_list\"]//td[@data-field=\"key\"]/div[text()=\"" & parameter & "\"][1]"}
This doesn't seem to work and the "fail" popup is not giving enough clue as I don't know if the {=getXpath("dossier")} part was interpreted correctly or not :
Side note : I tried to use this (string rendered inside the note in the snippet) in my chrome console and it does get me the right element of the page :
$x('//div[@class="oe_view_manager_view_list"]//td[@data-field="key"]/div[text()="dossier"][1]')
Any ideas why it would fail ?
Thank you for your help.
Sorry for the confusion. This feature isn't available yet. I was just asking if the snippet syntax I suggested would work for what you need.
Oh, my bad, I misread your post I think.
Yes, this syntax would be great.
@Gaurang_Tandon
Seems like you can tag this one as implemented.
Thanks to the whole team.
Awesome, to update the thread, we launched this feature in May:
