Persistent Dock-able/Floating Window?
Hey! Hope this message finds everyone well during these weird times :mask:
  • I was wondering if it were possible to add an option for a persistent "Window" that would allow users to simply click on a "Shortcut(s)" and have its contents inserted.
  • Window would have "docked" or "floating" options.
  • If floating, then perhaps an additional "always on top" option.
  • Window would provide layout options for the Shortcuts: by folder, recent, alphabetically, by date, etc.
  • Window would have a search feature to more easily find Shortcuts.
  • Cursor focus should work intuitively such that clicking a Shortcut doesn't require an additional click to return focus to workspace.
On a side note, I run an Online/Virtual Latin Dance Studio :dancer::man_dancing::grinning:, and as I interact with potential students find myself repeatedly typing out the same information over and over on FB, Insta & WhatsApp. I recently started using an app called "WordBoard" on iOS and found it very helpful, and I was looking for something similar in Windows 10.
That's when I discovered this nifty Chrome extension. Even though I just started using it, it looks like it's going to save me a ton of time. Kudos to the developers!
Thanks & Regards,
Alex
Love this idea. This is something we should explore further.
Note that you can click on the Extension icon by your Chrome URL bar to open open a window like this. It doesn't persist though.
Thanks for the prompt response, @scott! I'm glad you find the idea worth pursuing :grinning:
Yes, I am aware of the window that opens on clicking the Extension icon on the Chrome URL bar... and it's lack of persistence :joy:
As I thought more about it, the built-in Windows 10 emoji pop-up window layout comes to mind :thinking:
Not sure if that :point_up: makes sense.
[EDIT1: I find myself labeling my Snippets with emojis either way, but maybe it's just me :man_shrugging:]
[EDIT2: The window can activate/deactivate via Hotkey(s), but it must persist :rofl:]
Yes! This would be super helpful. Currently I keep my TextBlaze snippet page pinned in a tab on my browser because I have so many snippets that I can't remember them all without referencing from time to time. It would be a huge time saver to have an option to have the page docked or floating.
Thanks for the feedback @Deborah_Lewis. I'll ping @scott on this.
this is realy the only missing for the windows version.
Any News if this will be implemented?
Thanks.
Update: Forget my post :wink:
Hi @Bob_derHund Welcome to the forum! :slight_smile:
And I am glad you figured this out. I will still mention this for the other users reading this post: you can press Ctrl+Shift+/ in the Windows app to get a floating window to insert your shortcuts.
