Yesterday i downloaded text blaze, created a snippet and succesfully used it via the 'right click' function.
Today, if I right click and scroll down to Text Blaze, the only three options are Open Text Blaze Dashboard, Reload Extension and Edit Last Used Snipped.
That's unexpected behavior. Are you available to join a quick Google Meet call with me to check the issue? Feel free to email me at gaurang@blaze.today
Forgive me - it was because I wasn't right clicking a text box! Feel free to delete this from the forum - user error...
On a different note, can I please ask two things:
If I want to share snippets (centrally managed) with colleagues to also pick up, is this a paid version?
Can you have folders plus sub folders (and maybe even sub, sub folders)? This is my use case:
Travel business that uses an online itinerary builder. Feature 200 properties, each with different 'Inclusions and Exclusions' that I want to be able to drop in at the (right) click of a button. However, a list of 200 properties is impractical to scroll through. I know we can have different folders to split the list, but I wanted to ask if sub folders were possible so that I would right click 'Inclusions & Exclusions' then see, for example Country>Location>property.
thank you - do I need the business plan, or can I get just use pro? On Pri, it says share snippets with up to 25 users - does this include central management of the snippets, e.g. I as admin add them, and everyone can then pick them up?
On the Pro account, if you share the snippets with other users, they'll also need to signup to Pro on their own to be able to use the snippets.
Other than that, some advanced features like interacting with data using Data Blaze require a Business plan to share the snippets.
You can view the detailed comparison here: Text Blaze Dashboard. If you prefer, you can first start with the Pro plan, and then upgrade to the Business plan later as per your requirements.
