I'm using Windows 11. Shift-alt-space (to bring up the pop-up assistant) is not working.
Try to configure it here: chrome://extensions/shortcuts
I am experiencing the same issue, but still on Windows 10. OS is updated, Chrome is updated, TB extension is updated. The hot key combination only brings up the Chrome file menu at the top left.
@Brad_Hedinger, @user136, we're aware of the issue and are planning on changing the default shortcut.
In the meantime, here's a video on how to change the keyboard shortcut:
The explanation starts at 00:33
I recommend using ctrl+shift+space
