Temporarily save snippets after insert
I'm pretty careful about being on the correct window or closing the windows when I am working with a snippet. However there are times, like just a moment ago, where I insert and due to some reason or another, I send the snippent and it doesn't make it into what I wanted to. I then have to gather the information back into a new snippet.
If there were an automatic save so that we could bring back a snippet that we had just inserted this would not happen. Or if there were a problem with not being on the correct window and Text Blaze not allow the snippet to be inserted, this would work also.
Hey @Santa_Laren , is your request same as that posted here: {Clipboard} Use / Help? That is, if the snippet insertion fails to go into the correct textbox, then it should be preserved instead of silently failing.
@Gaurang_Tandon , Yep that's it alright! Sorry I hadn't had a chance to look at the forum as I've been busy. Thank you for looking into this for us.
This feature is now available in the extension :tada: See May Development Update for more details.
Hello, is this feature available in Mac desktop app? My Snippets are silently failing - I believe there was a prompt when I was on the chrome extension but I no longer receive that. Is there a setting I could be missing? Having to rewrite something already submitted is a big time sink, and my team doesn't like formfill / complex snippets because accidents are going to happen. One of my snippets is for research in which I need to go to their account, linkedin, and Chatgpt to insert my snippet. Even when I place my cursor back into the original source box, I feel it's not reliable that it will apply the snippet. Any help would be appreciated. Thanks!
Hi @Tori_Scharadin,
Sorry to hear about the issue you are facing. I have sent you a direct message with an invite to check it on a quick video call.
