AI snippets: request for beta testers
UPDATE: We launched AI Blaze - a dedicated browser extension for all your AI needs. It does everything below and a lot more. Check it out here: AI Blaze: AI Writing and Editing
Hey folks! We are trying to make it easy and flexible to use AI in your Text Blaze snippets :robot:
We are looking for beta testers to try this feature and give us critical feedback. If you have tried our previous AI integrations (command pack, API calls), then we especially look forward to hearing from you! :slightly_smiling_face:
Get these snippets by copying them from this Gallery link
For customized help, please email us at support@blaze.today, and let us know your workflow.
Dynamic AI requests
Copy data from anywhere and ask the AI to explain it briefly:
ai4
Generate personalized responses
Respond "yes" to conversations in a personalized way:
ai1
Polish your text automatically
I used it here as a substitute for Google Translate:
ai3
Looking forward to hearing from you all!
@Gaurang_Tandon
What a surprise.
The processing speed is so fast.
I'm glad you like it :slightly_smiling_face: Feel free to share more feedback here or on my email ( gaurang@blaze.today) We're constantly working to improve this feature.
7 posts were split to a new topic: Combine AI snippets output with regular snippets
Can you update to newer model gpt-4o-mini, it's cheaper and more capable, i.e vision?
This is updated to gpt-4o-mini although it's not yet having vision capability. I recommend waiting for a new AI announcement coming end of this month :slightly_smiling_face: Or you can email me if you'd like an early sneak peak :wink:
Awesome :grin:. I will email you ASAP..
were do we cant share AI Snippets?
{note}
⯏⯏⯏⯏ {{^^%E2%98%A0^^}} Dark Tower RPG {{^^%E2%98%A0^^}} ⯏⯏⯏⯏
On this RPG you will use dices to archive your actions, you have 3 life's.
{{^^%E2%AC%87^^}} Create your Character:{{^^%E2%AC%87^^}}{endnote}
{note: preview=no; insert=yes}Take the role of an strict role playing game master. I will be an adventurer. Use emojis as a part of the situations,{endnote} use a {formmenu: default=short; detailed} amount of words to describe the situation, {note: preview=no; insert=yes}Always show only one situation at a time, and 3 options to perform actions in that situation. player has 3 life's, if player lose 3 life's, player die. use a dice to determine if actions fail or success.{endnote}
My Character name is {formtext: name=name} and i am {formmenu: default=Male{{^^%E2%99%82^^}}; Female{{^^%E2%99%80^^}}; name=gender}{formmenu: {{^^%F0%9F%92%AA^^}}Barbarian; {{^^%F0%9F%A7%99^^}} Mage; {{^^%F0%9F%90%BB^^}} Druid; {{^^%F0%9F%9B%A1^^}}Paladin; {{^^%F0%9F%92%80^^}}Necromancer; {{^^%F0%9F%8F%B9^^}} Ranger; {{^^%F0%9F%93%BF^^}} Monk; default={{^^%E2%9A%94^^}} Warrior} coming from{formmenu: default=Arcadia City {{^^%F0%9F%8F%B0^^}}; Netherlands {{^^%F0%9F%8C%8B^^}}; Dark forest {{^^%F0%9F%8C%B2^^}}; Iron Islands {{^^%F0%9F%8F%9D^^}}; Mountains of whispers {{^^%E2%9B%B0^^}}; Comarca {{^^%F0%9F%9B%96^^}}; name=town} to challenge the dark tower. my personality is {formmenu: mysterious; default=charming; rude; evasive; angry; rebel}. I must play on {formmenu: default={{^^%F0%9F%9F%A2^^}} Easy\ ; {{^^%F0%9F%9F%A1^^}} Normal\ ; {{^^%F0%9F%9F%A0^^}} Hard\ ; {{^^%F0%9F%94%B4^^}} Ultra Hard\ ; name=difficulty} difficulty mode. the IA should be: {note}{formmenu: Creative; default=straight to point; Short; Flexible.; Strict}{endnote}
Thanks for sharing the cool snippet :slightly_smiling_face:
Yes, it's not possible to share AI snippets yet in the community, but we're working to set it up in place.
When we use the paste function, the first sentence gets pasted like:
"Here's the translated message in Spanish:
Examen físico annual"
It would probably fit more workflows if the copy did not include the first sentence generated by the AI.
If you translate into the same language frequently, you can modify the Translation Snippet to Translate this message to Spanish
(replace Spanish to another language if needed).
Saves time by not having to pick the language manually each time.
Thanks for your feedback Timothy. Does the AI highlight the resulting translation in a yellow box? If so, you can click the yellow box to insert the resulting translation directly. Let me know if it works for you.
Clicking the yellow box or clicking the Apply Changes to Page button does not work in my use case. I have to copy and paste the AI answer. Hence, I sometimes get the AI "Here's the translated message in Spanish:", which I then have to delete.
Thank you for your feedback. We're working on adding the copy button to the yellow box and it should be live soon (in the next month).
